ignition chime PITA
ignition chime PITA
Is there an easy way to stop the annoying "ding" chime the keeps going off with the ignition key inserted and the door left open? Is there a relay that can be easily accessed and pulled without disturbing other system functions?? I want to be able to use my stereo with the door open and without having the car running, etc..
Re: ignition chime PITA
http://www.iwsti.com/forums/how-install ... orial.html
The above is true for my Baja at least, I can not speak for other years.
Spent 30 minutes under my dash tonight, and I am certain my chime comes from that box.
If I get time this weekend, I may go ahead and do this but instead, unsolder the speaker.
I'll take pics and do a write-up.
Are you sure that this chime is the same one as for the seatbelt chime solution that is mentioned in that link? I did that trick for my seatbelts years ago and it worked for that purpose, but I still get the chime when the key is in the ignition and the door is open (or even closed and the engine is off)......Maybe I just didn't do it long enough.......I can try it tomorrow again and see if it works. Thanks for the reply!Rizzo wrote:http://www.iwsti.com/forums/how-install ... orial.html
It's not the same, although I don't have the belt chime and I have no idea why.
