Every vehicle I've owned (that was a manual trans):
1. I put in 1st gear
2. I hit gas
3. I watch the tac.
4. I listen for the engine to increase it tourk (sp.) producing sound
5 once the sound changes I've found the sweet spot called the power band where the engine is most efficient to shift gears at (this is so the engine isn't strugling when I shift and it isn't racing when I shift; unless I'm racing
![666 [smilie=666.gif]](./images/smilies/666.gif)
My problem is I think 2500rpm is too high and the engine is so smooth and so quiet that I can't tell without dinoing it and I don't know where to find an AWD dino.
So do you know where the Turbo Baja's powerband is?
eblanks
