Hi all,
I just picked up a 2004 Mystic Blue Pearl Baja sport a couple of weeks ago. Finished my first mod within a few minutes after scanning through this forum. I took the back headrest off. Will see if it improves my blind spot on the next drive which will be in a few minutes after this post. I'll be turning off the DRL's next. I'm looking for a replacement antenna and have a few other mods I've seen here that I want to do.
Just wanted to say thanks for making this great forum and I hope it continues for a long time.
Mike
New Baja owner
Re: New Baja owner
Hi!! Welcome to Scoobytruck.
Re: New Baja owner
NIce!!! Welcome to the club!
BTW, How did you actually go about getting the back headrest off anyway?
Dragonturtle
Re: New Baja owner
Thanks for the welcome.
The headrest were very easy to remove. I lowered the back of the seat and the headrest are bolted on the back wall. There is a panel that I pried open from the top. Then I used a 13mm socket to unscrew the two bolts. The headrest fell right off. I didn't want to loose the bolts, so I screwed them back into place. I put the panel back on and repeated for the other side. It took all of about 5 minutes for both.
The difference in driving is huge! My blind spots have been cut in half. Backing out of a parking spot is much easier with twice the view.
YBajaSteve
Re: New Baja owner
Hey welcome to Scooby Truck! Thanks for the good idea about the headrests!!
Dragonturtle
Re: New Baja owner
Thanks for the welcome Steve. I know I don't get the credit for that idea, I found it on the forum here somewhere.
I just got back from a 1,131 mile weekend road trip. I must say that I'm VERY impressed with my truck. It was a great smooth ride and it had plenty of power even at a steady 80 mph. I gunned it to see how it would respond and was pleased to see 100 in a couple of seconds. Don't worry I backed down to a normal driving speed.
I got a few looks and several smiles as I passed and got passed. I was disappointed to only see two other Subaru's on the road (one was a Baja). The biggest problem I seem to be having with my truck is the DRL's. I keep forgetting to turn on my lights after dark. I have a few ideas about how to solve the problem and keep at least some form of DRL's. After I do some research and see if it will work, I'll share with y'all.
Well, I've rambled enough for now.
Mike
Mike
Re: New Baja owner
Do some searching around here as well as Nasioc.com and you will be able to find plenty of info about changing the DRLs. Legacy forums are also a good place to find ideas and tips regarding your baja since the 2000-2004 models are very close to the baja.
