Hi,
My hood release cable has fallen apart, disintegrated, and I can no longer open the hood by pulling the handle in the passenger compartment. Does anyone know of a part similar to Subaru 57330AE00AOA that will fit? I can get the hood open by using a long screwdriver to activated the latch, but need to replace the cable.
Thanks,
Jim
Hood release cable
Re: Hood release cable
Should be the exact same part/assembly off a 00-04 Legacy or Outback.
Should be able to also find said cable by the foot at your local hardware store.
arizonarotors
Yes. It is the same part number, except for color as the Outback/Legacy. I think I will remove the current cable, measure it, and try to find a Dorman equivalent.
Jim
Jim
arizonarotors
I ended up using a Dorman 912-414. The ball is slightly smaller but does not appear to be in danger of pulling through the hole in the latch. There is a small aluminum piece about 18 inches from the lever end to remove but that took 3 or 4 minutes.
