06 struts
Re: 06 struts
Hey there!
Yes the 2000-2004 Legacy/Outback struts are slightly different but are 100% compatible. 2005+ Legacy/Outback struts are not compatible however.
See these two posts for more details: viewtopic.php?p=20136#p20136 and viewtopic.php?p=21255#p21255
Re: 06 struts
The outback struts are shorter, so if you want to do those you really should replace all 4 struts so your car isn't "raked" and handles differently (worse).
You can still get struts through the dealer last time I checked. Not as expensive as you'd think.
Re: 06 struts
yea not sure I'd call that 100% compatible... they bolt up but will lower the Baja.Guacamole wrote: Wed Oct 23, 2019 7:32 pmHey there!
