03 Baja Hitch Wiring Question..
KevinBlow
Post by KevinBlow »
I want to install the hitch and wiring myself. I found out how to install the hitch which looks super easy. But I can't find anything on the wiring. Do they make a direct plug in? or do I have to tap into existing wires. I'm not even sure where the hook up is. There's videos all over the place for installing the hitch, but no pictures or videos on the wiring. Any help would be awesome!
sfeather11
Re: 03 Baja Hitch Wiring Question..
Post by sfeather11 »
The baja is pre-wired for a hitch harness. Look under your car near the right rear wheel well and you should find a plug that goes nowhere. If I recall it is just inboard of the sill and ends a little behind the rear axle area. Beware that the plug has a dummy cap on it to keep all the dirt out that has to be removed, and it is a major pain to remove. If/Once you find the plug, Subaru makes a direct plug and play "T" harness that requires no cutting or splicing. I believe there are other aftermarket harnesses that may plug in, but not sure as I kept mine oem...
Peace!
[smilie=666.gif]
johnep
Post by johnep »
I bought an aftermarket direct fit plug and it came with directions. Showed the factory plug and location. Was very easy to do.
chuckster
Post by chuckster »
sfeather11 wrote:The baja is pre-wired for a hitch harness. Look under your car near the right rear wheel well and you should find a plug that goes nowhere. If I recall it is just inboard of the sill and ends a little behind the rear axle area. Beware that the plug has a dummy cap on it to keep all the dirt out that has to be removed, and it is a major pain to remove. If/Once you find the plug, Subaru makes a direct plug and play "T" harness that requires no cutting or splicing. I believe there are other aftermarket harnesses that may plug in, but not sure as I kept mine oem...
Peace!
[smilie=666.gif]
Are you serious??!!!
I wired mine myself, removed both tail lights, ran wires, took about 3 hours. Yeesh!
Thanks for the info [smilie=coolup.gif]
oldpro
Post by oldpro »
johnep wrote:I bought an aftermarket direct fit plug and it came with directions. Showed the factory plug and location. Was very easy to do.
Wow; where did you buy the aftermarket plug? That sounds so simple. The hitch is the easy part, wiring is something I'd rather not spend hours on if a direct fit plug is available!
Scrappy-Doo
Post by Scrappy-Doo »
Do a quick search on Amazon. I got a bunch of easy-to-do stereo/speaker wiring from it/them and I'm pretty sure you'll find some good stuff cheap and easy for your application.
MKKMikey
Post by MKKMikey »
Amazon links for the correct harness...
http://www.amazon.com/gp/product/B00307 ... ge_o07_s00
The cool magnetic mounting bracket (this was the fourth bracket I tried... Don't recommend the others that Amazon recommends)...
http://www.amazon.com/gp/product/B000CM ... ge_o03_s00
