Not sure if I'm in the right place BUT
Just bout a 2005 Baja 88K mikes - I think its all stock
I was looking at the intercooler and it seems that the fins on the top are all bent and close shut. Is that normal and should I try to open them ?
Intercooler fins bent closed - Advise
Re: Intercooler find bent closed - Advise
They should be open. Can you post a pic ? Fin straighteners are readily available. What percent of them are bent?
Re: Intercooler fins bent closed - Advise
Looks like most of them are closedtomato_88 wrote:They should be open. Can you post a pic ? Fin straighteners are readily available. What percent of them are bent?
I took pics lets see if I know how to post them (I'm a noob)
DoubleD wrote:Looks like most of them are closedtomato_88 wrote:They should be open. Can you post a pic ? Fin straighteners are readily available. What percent of them are bent?
I keep attaching a file (even made it smaller) but It won't go - I tried IE and Firefox
I guess I'm not allowed to post or upload files
OK Lets try this
Here's some photos
I got the pics. Those definitely need to be straightened. I would get a fin straightener and give it a try. If that won't work then you should replace the intercooler. You should be able to find a used one fairly easily.
I tried opening them with an exacto knife / razor but like I said they are awfully thin and bend real easy like. I'm not sure if I'm making it better or worsetomato_88 wrote:I got the pics. Those definitely need to be straightened. I would get a fin straightener and give it a try. If that won't work then you should replace the intercooler. You should be able to find a used one fairly easily.
They should bend back to shape at least once. It's a slow meticulous process.
