O2 sensor circuit high voltage bank 1 sensor one
Danfzzl
Post by Danfzzl »
Check engine light came on and that was the error code I got when I tested it. anybody change this O2 sensor before? if so are there any tips or tricks to do it?
Dan
http://theravensedge.com/
sfeather11
Re: O2 sensor circuit high voltage bank 1 sensor one
Post by sfeather11 »
Just did it myself a few months ago. No tips or tricks though. It is pretty straightforward. Unplug the old harness end, unscrew the sensor, screw in new sensor, plug in the new harness...
Once you unplug the harness end of the old sensor, cut the harness off at the sensor before you try to remove the old one. This will allow you to use a box end wrench to help prevent slipping. Use lots of PB blaster around the threads of the old sensor before removing. Routing the new harness is a little tight, but not too bad. I seem to remember having to use an extra tie wrap to keep the harness away from exhaust...
Peace!
Ahzlon
Post by Ahzlon »
Or if you are lucky or know a friend. One of these tools is AWESOME! I own a set that is a bit smaller but works great.
Danfzzl
Post by Danfzzl »
Hey man witch sensor did you replace? mine is the bank 1 sensor 1. and that bad boy is $175 is there any way to test the sensor before I drop 2 bills on a new one I might not need?
Dan
sfeather11
Same one, bank 1 sensor 1. Unfortunately $175 sounds about right for the price too. I seem to remember the dealer checked the old sensor with a multimeter and the reading (resistance?) went through the roof, which confirmed it was bad. Once I installed the new one and cleared the check engine light, all was good...
Danfzzl
Post by Danfzzl »
Dang, ok cool man thanks.
Dan
