Other gauges installed as pictures show.( Oil psi & temp. gauges came with sending units, Boost came with plastic pressure line).
Purchased a new oil drain plug from dealer, drilled and tapped to fit temp sending unit. Mounted Oil psi sending unit to Intercooler and tee'd OEM Oil psi sending unit. Wrapped all wiring with Fiberglass electrical tape for heat protection. Oil psi/temp and Voltmeter have blue led backlights, Boost gauge has a green backlight to match instrument cluster lighting. To install gauge pack, I removed front Bezel from storage compartment under stereo. Then cut and painted a 1/8 " thick piece of acrylic and superglued over storage unit. Then removed excess storage compartment plastic to fit gauges, used OEM screws to secure to stero brackets. Intallation was labor intensive but well worth the money saved.Total cost $290 for gauges, $6.00 for drain plug, $20.00 for fittings/wire/connectors and paint and a full day of labor.
