back head rests
rfugitt
back head rests
are the back headrests removable ? i tried pulling up on them, but they didnt move much...I would like to give myself more visability out the back window.
ray
ray
I always wonder the same thing. Especially when I am wanting to change lanes. But I am always wondering what it would look like with them off if I can get them off. And if there is nobody in passenger seat I even push it down all the way, then if anyone gets in the seat they have to adjust it. I always tell them it blocks my blind spot too much.
Fuzzy
Fuzzy
- Flowmastered87GL
daloon,
thank you for the wisdom on the rear head rest, for some reason i was under the impression that it was a difficult task. Took me less than 5 mins easy.
everyone else:
you will need a small screw driver (flat head)
1/2" size socket for bolts
lower seat and remove plastic cover under head rest using the small flat head, this part easily comes off. you will then see 2 - 1/2" bolts. get em out of there and thats about it. the bolts are not hard to loosen at all.
you must do this to realize how awesome the rear visibility is, screw the whip lash, its worth it
everyone else:
Woah guys, it wasn't meant to be a personal attack on any of you. I was simply trying to get the correct info out there. Lighten up a little.
If you do the math, 1/2inch equals 12.7mm which is more than 12mm and less than 13mm and therefor, although close, not the same.
The two bolts that secure each rear headrest are 12mm. (at least they are on a 2005 turbo)
There is an excessive amount of slop if you use a 1/2inch wrench on a 12mm bolt (it will fit pretty snugly on a 13mm though)
Sorry if my earlier quick response offended any of you, Just trying to get the correct info out there.
