Weird gurgling/popping noise on the highway from the rear when in 4th or 5th gear when letting off the gas
BlubaruBaja
Post by BlubaruBaja »
Just started today in the rain, my initial guess is running rich from
a bad map sensor? I cleaned it last week bc the car would turn on and then off unless I gave it some gas and held the pedal to idke at 1k. Which worked for a week then that started happening again as well.
Re: Weird gurgling/popping noise on the highway from the rear when in 4th or 5th gear when letting off the gas
Maybe something to do with the Idle Air Control motor? I've never had to mess with that before, but looks like it's easily removed with a couple of screws. Could make sure it moves correctly, isn't sticking or blocked anywhere, and there's no corrosion on the electrical connector.
