I'm thinking to remove the body kit from the doors for painting purposes, due to seals covering at top part are discolored and don't look great on my 04 baja.
Has anyone removed those panels? Are they difficult to remove? Any tips anyone have before I pull one off and ruin my ride
Thanks ahead guys!
Jud
Body Cladding comes off with clips and couple screws. Just removed all of my cladding for new wheels and bedliner paint. Will do cladding and bed in black, top in Green or camo.
Just be careful with the attachments, pull carefully. If you break some, you can get replacements at AutoZone.
The Seal Strips on top of the cladding are about 25$ each. You can order them from online subi parts stores; I can find the part numbers again if you need them.
SupeRoo Baja wrote: Tue Apr 06, 2021 9:46 am
I would also appreciate the seal strip part numbers if you can find them.
Here are those numbers, I think that's all of them. They come in different colors, and the Left side rear is different from the Right side rear due to the gas cap.
Located under 'Body -> Outer Garnish. Side.'
Front Fenders: $29.10 Each
Fender Protection Film: (Silver, Black, Bright)
Part Number: 91163AE37ANN
Supersession(s): 91163AE37ALI; 91163AE37APL; 91163AE37ATC
LH Side Body Trim: $11.51
Side Body Trim Protector (Silver, Black, Bright)
Part Number: 91163AE31ANN
Supersession(s): 91163AE31ALI; 91163AE31APL; 91163AE31ATC
RH Side Body Trim 1: $7.10
Part Number: 91163AE32ANN
Supersession(s): 91163AE32ALI; 91163AE32APL; 91163AE32ATC
RH Side Body Trim 2: $11.51
Side body Trim Protector (Silver, Black, Bright)
Part Number: 91163AE33ANN
Supersession(s): 91163AE33ALI; 91163AE33APL; 91163AE33ATC
