walfredo wrote: Wed Oct 10, 2018 7:21 am
I was going to guess sticking rear brake caliper - parking brake being set would cause the caliper to close. Brake caliper being stuck would cause it not re-open once you release the parking brake. The brake pads will begin to overheat (and smell) as it remains clamped to the rotor. Very common issue on some cars (vw's especially). Im not sure how the parking brake would cause this, as its cable operated and when you release the handle, it should release-unless there is something wrong with the linkage. The caliper is whats remaining clamped to the rotor.
Easy to fix yourself and you can get used calipers fairly cheap. As far as driving it, in a pinch you can probably drive it, but only in order to limp it to the mechanic. Be prepared to do a rear brake job (rotor, pads and obviously caliper if thats the culprit) as those components may be warped/destroyed from the heat.
Also, if it were a bad wheel bearing, you would hear a very loud and noticable "groan" at different speeds (noticable at some, not noticable at others). Furthermore, it would also be louder turning one way vs another (as the vehicle weight shifts more strain onto the failing bearing). They can cause excessive heat, but not to the point of what you describe, at least in my experience.
The bajas use a divorced parking brake setup. there's a drum brake inside the service brake disk. the parking brake actuates the drum, the pedal actuates the caliper. The service brakes can be 100% functional with a stuck, dead, or completely removed parking brake.
In my experience having diagnosed and changed dozens if not hundreds, bad wheel bearings can cause a huge variety of symptoms:
-vibration at all speeds
-vibration at certain speeds (as small as 2mph window)
-growling from a stop
-pulsing or phasing noise (vibe or noise gets louder and softer with a regular oscillation like twisting a volume knob back and forth)
-wind noise
-no noise or vibration
-symptoms seem to be coming from the opposite side of the car
-symptoms seem to be coming from the opposite end of the car
-little noise but heat to the point of turning the rotors blue/gold (700f+. no they don't last very long that way)
Heck I even saw a van once that the guy'd put it off so long that I only found half a dozen roller bearings, he was grinding the races together with dirt as lube. Didn't take that one for a test drive on the road, bad enough driving it into the shop.
