My '05 NA 5MT is having a very specific misfire issue. Above 3000 RPM at a steady speed while on Cruise Control, such as a freeway, when the cruise lets off ever so slightly, I will get a misfire code for cylinders 3 and 4. This only seems to occur above 3K, I can be going 55 or 60 on cruise, for example, and the problem does not occur. Also, if I am just driving using the gas pedal over 3000 RPM (or under), i cannot replicate the problem no matter how gingerly I try to let off the gas. Additionally, when the cruise control comes back on the power, such as to maintain a steady speed on flat ground, or to climb a hill, the MIL light goes out and there is no misfire issue...
I replaced the spark plugs and plug wires, which were both in dire need of replacement, but it did not make any difference in the issue.
Could this be some type of vacuum issue related to the cruise control?
It has 166k miles and had head gaskets at 100k. When I changed the plugs, they were well worn, but had no signs of any oil leakage or oil burning, and, obviously, all new plug/wire connections are good.. I had seen a few previous topics about cleaning the coil pack connector, so I will try that. Next on the list will be coil pack replacement, especially since 3 and 4 are on the same half of the pack, but was holding off on the $150 for some more input...
Thanks for any ideas, other than just driving under 3K RPM!
