Greetings!
So I recently picked a 2001 outback 3.0 (non-VDC) for dirt cheap. It's headgaskets are bad but other than that it is running very good. I did some reading on what it takes to swap the EZ30 and it seems fairly simple and I think I can handle the mechanical work. I'm not as electrically inclined as I'd like to be, so with that being said, I was wondering if I could get some help from others that have done it.
-What do I do with the parts of the new harness that don't have anything to go to? I don't plan on swapping the seats, heated windshield/mirror components, etc.
-How should I wire up the rear cargo/tail light over the bed?
-What are some components that I need to swap over to make the harness work?
Thanks!
EZ30 Swap into a 2003 NA Baja
spitsomeearth
Re: EZ30 Swap into a 2003 NA Baja
the engine and body harness are separate. you need to get the PCM and engine harness along with the engine and adapt a few pins/wires to your body harness.
