Hey folks, people online make it sound like all Subaru Bajas will eventually need the head gasket replaced. Most by 150k miles. Some by 100k. Is this accurate to your experience? What percentage of 03 Baja owners would you guess have had to change the head gasket in the vehicles' life?
Thanks!
How common is head gasket replacement?
Re: How common is head gasket replacement?
As mentioned elsewhere: I have a 2005 Turbo AT with 166,000 on body bought used in NJ this past July...it has had 2 dealer engine replacements and with 34k on new engine dealer reported “oil around head gaskets” during banjo bolt replacement...I think we can consider the engine replacements as including “head gasket replacement”deanrocker wrote:Hey folks, people online make it sound like all Subaru Bajas will eventually need the head gasket replaced. Most by 150k miles. Some by 100k. Is this accurate to your experience? What percentage of 03 Baja owners would you guess have had to change the head gasket in the vehicles' life?
Thanks!
But maybe I’m being unecessarily negative...just got a $2500 estimate from my MINI mech to “maintain” my 92,000 mi. 2012 Cooper Base (no turbo) hatchback (timing chain & water pump related stuff, plugs & coils, shocks/struts/endlinks, ...took it in for 2 check engine lights...
Previous 2007 Cooper S imploded twice at 36k and 52k covered by warranty - the dreaded timing belt tensioner & fuel pump issue (now class action lawsuit)... #whocaresreally
Civic or Corolla only real solution I believe:)
Most will. Luckily it's usually non-catastrophic: the oil drainback leaks at the lowest point.
I still need to do mine. It's been slowly leaking oil for the 10k miles I put on it and who knows how long before that.
Replaced the gasket on my 03 at 236,000, only because it had a very small leak, did the oil pan gasket at the same time.
My experience with the EJ251 and EJ253 is that they will all need to be done at some point. Usually around 100k miles. I drove my 03 Baja for 30k miles with weeping head gasket on the passenger side. I eventually changed it because I was tired of it smelling when I parked it.
Sent from my Pixel XL using Tapatalk
