Performance questions
memphis212
I have a friend with a 2005 lgt. It has a few things done to it. Downpipe, cat back no name intake etc etc. running on Cobb stage 2. He is about to trade the car in and said I'm welcome to anything on it. Swapping out for my stock stuff of course. Could I take all of his parts along with his ecu and Cobb and direct bolt on everything minus the exhaust ? Would my ecu run his lgt without issue ? Should I instead hunt up a different ecu to be able to use the Cobb?
Re: Performance questions
Do u have a turbo? And Cobb is paired to ECU it was programmed with. If everything is the same, you could do it. It would be possible, but you have to use his ECU and the Cobb together, once they are paired, they can't be paired to another ECU unless you bring it to Cobb, then its not worth it after that.
