Does anyone have a link or info that shows the Baja colors by year please? ...and if it had the actual factory paint codes that would be even better : )
Thanks in advance
Adam
05 Sport
Baja Color info
Baja Color info
Adam C.
DFW Area, Texas
2005 Baja
2005 Outback Limited
(76', 77', 81', 82', 83', 88'(2WD), 89, 92, 05', 05' - all were wagons,except the Baja)
Yep,... not much I have not seen on a Subaru.
DFW Area, Texas
2005 Baja
Re: Baja Color info
Here you go:
http://www.cars101.com/baja.html
Each model year had different color options so just open the product year link & you'll get the info you're looking for.
Re: Baja Color info
Fantastic - thank you!Guacamole wrote:Here you go:
Adam C.
DFW Area, Texas
2005 Baja
DFW Area, Texas
2005 Baja
- NevadaWolf
Re: Baja Color info
Sorry to piggy back on this, but is there a way or a guide to which part code will match which color?
I need the fuel door cover, but since it matches multiple colors, not sure which to order.
See?
Stock Code
57620AE00A ; 57620AE00ABE; 57620AE00ABH; 57620AE00ALI; 57620AE00APL; 57620AE00ATC; 57620AE00ATE
See?
Stock Code
Re: Baja Color info
I'm unsure about the color codes, but I hope I can make it a little easier:NevadaWolf wrote:Sorry to piggy back on this, but is there a way or a guide to which part code will match which color?
See?
Stock Code
All two-toned bajas used the color of the lower trim as the color of the fuel door, & the monotone ones used the body color.
So...
If yours is a two-tone 03, it'll be light silver.
If yours is a two-tone 04 or 05, it'll be either light silver or dark grey.
If yours is a monotone 03-06, it'll be the same color as the body.
Hope that helps!
- NevadaWolf
Re: Baja Color info
Yeah, I have the "Sept 2003- new Mystic Blue Pearl monotone color available on Sport model only"
I just am not sure which part number equates to that color. BUT since my hood needs repainting anyway, I'll probably just buy any of them and have the painter color match it.
Thanks!
Thanks!
Re: Baja Color info
Ok, all helpful, but so where can I find a link that specifically gives Color and Trim Codes?
My '05
Trim Code: 010
Color Code: 35J
Option Code: U4RG
So... what do I have?(!)
My '05
Trim Code: 010
Color Code: 35J
Option Code: U4RG
Adam C.
DFW Area, Texas
2005 Baja
DFW Area, Texas
2005 Baja
Re: Baja Color info
^ Regal Blue Pearl, should be monotone color.
From NASIOC:
http://forums.nasioc.com/forums/showthr ... ?t=2179532
Paint Color Codes for Subaru Baja
2006 Subaru Baja
Obsidian Black Prl 32J
Atlantic Blue Prl 33A
Brilliant Silver Met 39D
2005 Subaru Baja
Garnet Red Prl 33J
Regal Blue Prl 35J
Monterey Silver Met 35Y
Onyx Met 36Y
Satin White Prl 37J
2004 Subaru Baja
White Frost Prl 01X
Mystic Blue Prl 17X
Regatta Red Prl 18X
Silver Stone Met 19X
Baja Yellow 23Y
Black Granite Prl 54A
2003 Subaru Baja
Mystic Blue Prl 17X (sport)
Regatta Red Prl 18X
Baja Yellow 23Y
From NASIOC:
2006 Subaru Baja
2005 Subaru Baja
Garnet Red Prl 33J
Regal Blue Prl 35J
Onyx Met 36Y
Satin White Prl 37J
2004 Subaru Baja
White Frost Prl 01X
Mystic Blue Prl 17X
Regatta Red Prl 18X
Baja Yellow 23Y
2003 Subaru Baja
Regatta Red Prl 18X
Baja Yellow 23Y
