What's this?
mikeeitup
What's this?
Post by mikeeitup »
I was snooping around under the driver side dash and I found these two connectors apart near the console side. One was on an orange wire and the other on a black wire with a blue stripe. Wondering if I should connect them and if anybody knew where they went? They seem to come out of a larger harness.
Mike
starr-
Re: What's this?
Post by starr- »
I forgot what they are for but they are supposed to be disconnected. A google search should reveal the answer pretty quick as it has been asked/answered many times on the forums.
starr-
Re: What's this?
Post by starr- »
Re: What's this?
^ thanks to starr-
They're flash connectors for putting the ECU in test mode. Connecting them resets the ECU, leave them disconnected.
mikeeitup
Re: What's this?
Post by mikeeitup »
Thanks guys!!!!
Mike
Bobsagator
Re: What's this?
Post by Bobsagator »
So is this an easy ECU reset? Honda has a fuse you remove, I was hoping there was something easy for the Baja.
~Fritter and waste the hours in an offhand way!~
