Rear brakes... dead at 30k?
- cyphergirl
That's right.. the dealership just called to let me know that while they are doing my 30k service they replaced my rear brake pads under warranty. They didn't find the cause.
WTF?! Rear brakes gone at 30k?!
- cyphergirl
Nope, haven't hauled much of anything. But when I asked my hubby how it could have happened, his answer was: "Because your husband drives like an @ssh*le."mbaksic wrote:mine still have lots of miles left in them. I have 42,000 on them now, and I figure that they should go to at least 50,000 the way they are wearing. Something is screwy there Patti!! Have you been hauling anything heavy in the box!! But at least you got it fixed to free
Mike
I've always been very easy on my cars, so I know I didn't wear them down. *grumble*
since we are talking brake issues..
On my 1st trip back to the dealer (100 miles on truck)my issues were:
pulsating brakes
shaking vehicle (2nd complaint on this)
door window sticks in weather stripping when opening
Results
Adjusted window
Replaced 4 rotors
Bad weather , couldn't test
Dealer is 48 miles away, happy about the brakes , didn't like response on vibration
Hope I didn't hijack thread , bought t-shirt
Mark
pulsating brakes
Results
Adjusted window
Replaced 4 rotors
Mark
My Baja has only 7500 miles on it, but I have noticed something wierd about the rear brakes as well. I noticed that the front rotors are clean with no lines on them, but the rear rotors have some slight grooves already in them and when I first took delivery up until a few months ago made a dragging type of sound whanever I applied the brakes.
I asked the dealership about it and they said that my particular vehicle sat at the dealership for several months before I bought it and it is probably rust that is causing the noise and to drive it about 5000 miles or so in mostly city type driving conditions. It seems to have worked since the noise eventually went away.
However he did say that they did replace the rear brake pads under warrenty for another Baja.
I will be paying closer attention to the brakes now since it seems this might be an issue.
I can see the fronts going alittle sooner than normal. Afterall the front rotors are the same diameter as the WRX which is 500 pounds lighter. But the rears are, as far as I know, the largest on any current subaru minus an STi and same diameter as LGT excpet not vented. The fronts do most of the work anyway. I find it alittle unusual that the rear pads wore out so much earlier than the rest. I'll be lucky if mine last 30,000 miles....
thetoadinpa
- cyphergirl
Have someone, maybe the dealership, check the brake light switch. If the switch isn't adjusted correctly, it may be holding some pressure on the brake pedal, even though the lite is off. It is a rare occurance, but I have seen it before. Also, remember that the Baja isn't like a fwd car. Its weight is spread out more like the old rwd cars, so the brakes will wear out at a different rate than a fwd car, meaning the brakes will wear out more even than if all the weight is up front. I remember, and have seen on pickup trucks, the rear brakes wear out before the fronts. Also, make sure you don't rest your foot on the pedal at all when driving, this will hold the brakes on slightly, making them wear faster. Thats all I can come up with right now. But I have seen this stuff on other cars in my 23 years in the shop. Hope this helps everyone out. Mike
do you use cruise control much? the brakes are applied to keep you at the selected speed when going downhill. this seems more pronounced on the baja's cruise control. I'm guesing it only applies the rear brakes to adjust speed.
also, the baja has the best parking brake i've ever had. I'm not sure it locks only the rear brakes, but if it does, leaving it on once or twice may have contributed to the wear.
finally, factory pads ain't what they used to be. I never even had to check the brakes for the 1st 50,000 miles in the "old" days. that would be a big mistake now.
at 25K, I got into the rotors on my F150. I checked the brakes at 20,000 on my Outback Sport, and had just a little left before rotor damage.
I'll be checking the baja at 10k, but now I'm going to pay close attention to the rears also. I never would have even looked before reading this thread.
Baja_Turbo
