up pipe downpipe, and headers
Hello, does anybody have any info on direct bolt on uppipe, downpipe for an 05 Baja turbo? Flex or no flex for uppipe? What brand is a perfect fit and quality? Also is it worth getting headers for the baja if so what brand? Any help will be greatly appreciated!!! Thanks scoobytruck!
Re: up pipe downpipe, and headers
I have the header and complete exhaust system from Xcceleration. Its beautiful and sounds great. First class build and construction.
Acro2pilot
I used an invidia downpipe which fits a lifted Baja, on a non lifted baja you have to remove the passenger side bracket that sits in the corner. Pretty much any STi header/up-pip combo will fit, I used an uneaqual length header with flex section up-pipe. Without the flex section you will probably have nightmare leak issues at the header/up-pipe joint. The downpipe is the money maker for HP gains but the up-pipe also contributes some and the stock one with its cat has vomited cat parts and ruined turbos. Header/up-pip combos are so cheap why not do it all.
