I inherited my moms 06 Baja as is. The turbo was replaced about 1000 miles ago and it appears to not be making any boost at the moment. I doubt it is the source of the problem but the factory IC y-pipe has a tear and will leak when it gets fixed and for diagnostics.
After enough searching and researching I have become mostly empty handed. Apparently information is very fleeting on these vehicles. This vehicle will never be anything other than stock so I don't need a 160.00 3 hose set. What crosses over or any decent after market pipes for a decent price?
Any known problems with no boost? For lack of a better term. any "boost control solenoid" issues?
Thanks for your time
need IC y pipe for baja
bdover9876
Re: need IC y pipe for baja
I would look at the boost control solenoid. I recently got a tune with the stock bcs and it wouldn't hold anything more than 12 psi. Maybe yours is going and only holding a few psi. Its a possibility.
I threw a grimmspeed ebcs on, got the Baja retuned and now its holding 19 psi.
Good luck with the Baja.
Boost solenoid is on my radar. Just need a pipe as I know it leaks, so I need it to continue diagnosis.
