I have an idea, But I need to trace down some wiring first.
Can anyone give me a few ideas on how the rear hazard/turn and brake light wiring looms are run ?
Wiring routing for rear turn and brake lights ?
- mikenmel08
Re: Wiring routing for rear turn and brake lights ?
Do you have to hit them in a specific spot or will anywhere in the line work? Easiest would be to just pull the rear lights out, but i don't know what you are trying to accomplish..
Would you believe I can't get the rear left out?
I pulled the plastic trim piece, Then the two bolts... It won't come out.
I'd like to get the line I see run from passenger side under the bed to the left?
Old thread I know. Have you done anything worth this? What model year?
Using Tapatalk
