In spite of my general dislike for Automatic transmissions I bought my Baja with/Auto because it was low mileage in like new condition. Although I love the little cruck the transmission shifting leaves something to be desired. I had the dealer change every fluid in the car right after purchase so I don't think it is a fluid problem.
I am wondering if this behavior is normal with 03 Automatics. First, when backing up, stopping, and shifting into drive it takes a few seconds before the transmission engages. Second, when driving rolling hills and transitioning from downhill to uphill at maybe 30 mph the transmission downshifts with a jarring shift.
Is this normal behavior for this transmission? I haven't noticed any other problems with it but the shifting leaves something to be desired.
If this is not normal, is there some adjustment that can be done or am I looking at major problems down the road?
I do wish it was a stick.
2003 Automatic Shifting
- TastyHuman
Re: 2003 Automatic Shifting
Have you checked the fluid level?
- TastyHuman
Yes, if anything when the fluid is hot it is slightly overfilled. Would that cause it? The hard shifts are the same hot or cold.hocrest wrote:Have you checked the fluid level?
I have the same vehicle, I was thinking of swapping in a 5 speed.... I however do not have that problem with the shifting.... It does shift pretty crisp if you are more than 50% throttle... but i have no problems with it hesitating to go into gear from park or reverse..... I really would like to have a 5 speed, I am unsure of what ones would fit as I think I remember reading that the Turbo and Non-Turbo 5 speeds where different???.....
2003 Automatic Shifting to slow. If you have the time and skill check your differential/tranny for recent work by the prior owner. It may not be assembled properly thus not giving you good power distribution from the tanny to differntial. Have a compression check...
SPORT Abe
2005 Baja Turbo
Arizona
2005 Baja Turbo
Arizona
Glad I found this, my 06 auto has roughly a 1-second delay when switching from neutral to reverse. It also takes a while to switch from 2nd to 3rd gear, like around 35mph. The 2nd-3rd lag doesn't happen if I'm just going down the country roads or main highways, but there's a few city roads here that are 25mph limit & the trans doesn't want to shift up. I'm almost tempted to force it into 3rd gear so I don't have to speed around there.
Subie tech changed the trans fluid & the filter & says the trans is fine.
