Transmission Range Sensor Malfunction
Hi guys, my check engine light has been on for quite some time now due to the transmission range sensor. It doesn't effect how it performs, but I need to get it fixed for inspection. I took it in to the dealer and they were pretty certain that replacing the sensor for $75 would fix my problem. Nope. Then they said the wire lead going to the sensor. I took it off, tested it, put dielectric grease on it, and the light remains.
If anyone else has encountered this and solved it or if you have any wild ideas, they would be appreciated!
Re: Transmission Range Sensor Malfunction
Give me some more info on your car and i will see if i can help at all. Also a code # would be nice
mikenmel08 wrote:Give me some more info on your car and i will see if i can help at all. Also a code # would be nice
'05 non-turbo auto. The code is P0705 (transmission range sensor circuit malfunction)
