CV Shaft Replacement
Ahzlon
Post by Ahzlon »
Hey all, found out something interesting while trying to replace the passenger side 1/2 shaft on my 05 Baja turbo today. Autozone lists the wrong 1/2 shaft if you have the shafts that do NOT use the spring pin. We did some comparisons and found out the one for the 06 Forester XT is the exact same. SO if you need to replace your 1/2 that do NOT use the spring pins here is the P/N Autozone.
Autozone
Duralast Reman CV Axel 10394.
Life Time warranty.
*lists as CV Axel for 06 Forester XT*
I personally haven't had any issues with reman'd 1/2 shafts so I will buy them. Hope this helps anyone else looking in the future.
