I want to install the column-mounted Subaru accessory boost gauge for my '06 Baja Turbo. Don't want an aftermarket unit. The problem is that Subaru has discontinued the part and I have been searching for one for two weeks now with no luck. The one I had in my '04 STi looked exactly like the one for the Baja. Anyone know the differences between the ones created for different models? I have no problem running longer hoses or making mounting accessories but want the wiring harness to stay intact for reliability and easy removal in the future if I want to take it away.
So will one for an STi, WRX, or Forrester plug in and work with light modification?
OEM Turbo Boost Gauge - What is the Diference Between Models
BajaWannaBSTi
Re: OEM Turbo Boost Gauge - What is the Diference Between Mo
the gauge itself is the same across the line (at least through 2005). You might find that the wire harness length may be a little different or something.
