Pulse Plugs
- adm_wiskyky
Pulse Plugs
Does anyone run the Pulstar pulse plugs on thier Bajas? I am about to instal a set on mine and wanted to compare results apples to apples.
Ad Majorem Dei Gloriam
Re: Pulse Plugs
ive tried a few different plugs...not these but the one i did try didnt seem to make much of a difference so now i always just go with factory plugs...in my opion they work great...ngk by the way from autozone
- adm_wiskyky
Re: Pulse Plugs
Yeah, I've always gone with NGK before but I was researching spark plugs (out of boredom) and out of all the "high speed" spark plugs out there the Pulstar pulse plugs had actual numbers: graphs, dyno charts, MPG, etc.; to back up their claims. They are a bit more expensive (about twice as much) than normal spark plugs but they use exotic metals so they should last longer (like other platinum and iridium plugs).
I guess I'll see how they do and post my results at a later date.
Re: Pulse Plugs
I have a set of the Pulstar plugs in my '05 turbo. They may have been a primary cause of why nitration was significantly reduced in my last used oil analysis. I believe that a certain flat spot in the low to midrange power area under very specific circumstances (including cold start, but not every cold start circumstance) is greatly reduced or even eliminated with them. However, there is no mpg difference and no reduction in fuel dilution in the oil. As such, the plugs cannot pay for themselves for me. YMMV.
- adm_wiskyky
Re: Pulse Plugs
The results so far: no real change seen in gas milage and I don't "feel" much change in power as I have no way of really measuring the power (dyno, acceleration, time it takes to go up a hill...) but I have a feeling any gains are miniscule if at all.
