Turbo Gauge
MikkoSuave
Turbo Gauge
Post by MikkoSuave »
Does anybody have a turbo gauge on their Baja? If so, what kind and would you recommend it. I just purchased an '05 Baja turbo and am thinking of putting a gauge on.
Thanks
Zooom
Re: Turbo Gauge
Post by Zooom »
unless you are modifying the output of the motor, I wouldn't even bother as it isn't much more than 8-12 pds I am guessing...so less than 1 bar on that type of gauge...
Semi13
Re: Turbo Gauge
Post by Semi13 »
Just got a boost gauge for my birthday a little while back,could anyone with experience on how to install it give me a run-through of what to do?
appreciated
Hawk296
Re: Turbo Gauge
Post by Hawk296 »
It's pretty simple to install. Just tap into a vac line and run it inside through a grommet of your choice on the firewall. The factory boost gauge has you T into the small vac. line going to the bypass valve on the intercooler. Once you run that inside and attach it to the gauge, you just have to tap the electrical into the illumination circuit.
