from that angle, its hard to tell, but they might look a little hazzy..... you buy them off Ebay? was the package looking a little tore up and maybe you got screwed over? u could always try that glass haze remover stuff they sell in auto stores, might help some.
Ok, good to know, I think I'm gonna try and clean it out with cotton swabs from the bulb opening... probably try windx or rubbing alcohol... unless someone has a better suggestion
Mine looked the same. . .I received them last week and installed them. . .when I pulled my car in the garage tonight I noticed one was clear! It has to be a bad seal around the light letting in all the humidity we have here! I took the cloudy one off, removed the bulb, and now it is clearing up. . .i'm thinking maybe a little vaseline around the seal and silicone around the wiring harness???
