I was towing a lawnmower on a 4X8 trailer at the time. I did not over exceed the weight limit nor was the rear end sagging. I'm not sure if it's just time for stuff to start breaking down like my Jeep Wrangler did now the car has 60,000 miles on it and is almost eight years old.
Anyone else have a CV joint boot failure at 60K miles? The outer joint boot looked fine. I figured those were more likely to fail than the inner boots. I will say it was much easier to pull the axles than on my 87 Yugo. One of the hardest parts was driving the pin out that holds the joint to the splined end coming out of the transmission.
It was a $15 fix but required about 6 hours to fix. The Chilton's manual was a great help. I'd invest in one if you plan on doing any work on your car.
