So I need to replace my front Subie emblem cuz its cracked, but I cant figure out how to get it off. Is it glued on where i need to heat it up to pull it apart or something? Is there a screw im missing or something? Thanks
N2Subies
How do you take off the front emblem?
YBajaSteve
YBajaSteve
Re: How do you take off the front emblem?
Anybody anything!?
So how did you do it?
YBajaSteve
turns out it is just like i figured, its just glue that needs to be heated up and then you kinda pry the emblem off, since mine was already cracked, i wasnt worried about breaking it. but ive also read you can use fishing line to slide underneath and slowly work the emblem off, like you do when debadging. It was fairly easy to heat up using just a blow dryer in its hottest setting. a heat gun would be ideal tho.
N2Subies
N2Subies
