Well I know that when I did my LED dash conversion, I used a Haynes Manual to get the jist of where the screws are, its actually really easy, I know you start at the plastic around the shifter, that just pops up, it has some clips that just pop in and out, (in my manual trans. I dont know if its the same in auto). Its two screws to take the lil change holder at the bottom of the dash out, you cant miss them, they are right there. then theres like 2 (maybe) screws near the 12V outlet that you take out, again, pretty easy to find, and then the silver trim around the radio and everything just pops out, again, with clips, you kinda have to pry it out, but being careful to not crack the plactic. and that bring you to the hazard light switch which can be unplugged from the harness. I think the plastic piece around the guages and over to the left vent all is one piece and just pops out. the next part it taking out the 4-5 screws that hold the gauges in, they are right there, you cant miss them, i think 3 on the inside edges, and two in the top. and then your gauges are out, you need to lower your steering wheel to the lowest postition too, btw. umm. yeah there are three harnesses on the top of the gauges, they unplug, then your guages are completely out. the lights are right there in the back, they just turn and pull straight out. I think thats about it. It sounds hard but when youre there looking at the car, its easy. I would suggest a haynes manual. they are good. the one I have says for the legacy and then it says also for 03-06 baja. its all the same anyways. Hope that helps!
whore out my car a lil more
