Anyone have the block heater?
Just wondering, we were thinking of getting one, hoping it would help that aweful start up knock in the am during winter...
Hey Blaze, I don't think that the block heater will get the pistons hot enough to make them expand enough to get rid of that piston slap. I had a block heater in my old Cherokee, and used it alot, and it still knocked like hell. Of course, that thing would have piston slap warm, on a 100 degree day. At least you would have instant heat when you got in to drive. I have a remote start, and let mine warm up about 15 minutes. Plenty of heat, but still has the piston slap until I drive it and get it fully warmed up. Mike
The hardest part of the whole project was finding a 14mm allen wrench. Finally found it at Auto-Zone.
Remove the plastic splash guard from under the front end, 5 12mm bolts and 2 screws, one in each wheel well.
Drain the cooling system. Drain is a little hard to find and has a plastic plug with a Phillips head.
Remove the 36mm plug from the block which is located next to the gooseneck that the bottom radiator hose attaches to. This is what the 14mm allen wrench is used for and it is very tight. You'll get about another quart of out when you do this.
Install the heater element in the whole using some good high temp sealant. Install the power cord and route it up front.
Put everything back together and you should be good to go.
2005 Sport, Atlantic Blue Pearl, A/T
Had to install a new one this summer. The original one burnt out last winter. Must have left it on to long or in to warm of weather.
I don't think it has a thermostat cause when I installed the new one and tested it, it started heating up right away on an 80 degree day.
Didn't bother using the radiator drain this time, just unscrewed the bad heater and let the coolant drain into a bucket. Ran the coolant thru a couple coffee filters before putting it back in.
