steven765 wrote:Well turns out you can add the heated mirrors, working on the seats next.
Hood has chipped alot from all the highway miles, I might get a new one.
Pow wrote:
Heated mirrors! My kingdom for heated mirrors! Has the swap process been documented, or did you have the dealer do it? I know there has been discussion but I don't recall a full step-by-step.
-Pow
Sorry for the much delayed reply
I did it myself:
I never did a step by step. It's actually really easy because it's pre wired.
But the steps are
1 buy heated mirrors from subarupartsforyou
2 buy switch with heat option in it
3 remove tweeder
4 remove inner door panel
5 disconnect and remove mirror (3 beefy screws) so use a big #3 phillips
Install new mirrors in orig location reuse screws.
4 carefully remove old switch prying apart plastic every so slightly snap in new
Verify everything works
Carefully reassemble door panels being careful not to pinch the wiring harness. I did this, shorted out two wires drove me nuts because it was under the tape so I couldn't tell it was done.
Presto heated mirrors.
Tools required voltmeter, various screw drivers, door remover tool, needle nose pliers, lots and lots of patience.
Note all the power wiring was there on my 06 sport. You may want to check that yours has the extra 2 wires in the mirror connector and they get power when you short the two extra wires on the switch (if they are there) otherwise it just became a interstingly more complex problem.
I've been poking about I would really like to have heated wipers next, but the wiring for the switch is not there. I need to take apart part of the dash and check the bulkhead wiring harness to see if it's in there. Then it might be worth doing.
I'd also like to add the lighted ignition ring too
Essentially I'll have all the options of a turbo without the extra fuel costs, I still think subaru was retarted for not allowing the leather package as an option on the sport.
