Sent from my SM-N950U using Tapatalk
Good to know, what about this banjo bolt I keep hearing about? Timing belt?roywitty312 wrote:Everything under the hood should look dry and leak free I'd also try listening for any shaft play in the turbo.
Got a friend that lives there that I haven't seen, so this is kinda a 2 part trip. It's currently going through an inspection, fluids are going to be checked, changed, and topped off.they understand my lengthy drive back home so they assured me they would check it thoroughly. I just didn't know if their was something specific that people knew about that I should be worried about. Once I get it back home I can get to wrenching and taking care of repairs and mods. I'm not shy with a wrench.Guacamole wrote:[spits out drink] 600 Miles??? And I thought 200mi for mine was wild.
So I have an NA, & don't know too much about the turbos or the specific parts they use, so take my 2c with a grain of salt.
Here we go
The banjo bolt is a type of filter inside a bolt that's fitted to the turbo oil-feed line. Apparently, the screen filter inside the bolt gets easily clogged from neglect. Some threads from here & other Subie forums have suggested to just outright remove the screen filter.
(see thread: viewtopic.php?f=3&t=3315&p=18561)
According to official Subie manuals, the timing belt should be replaced every 105k miles. The belts are behind a plastic cover on the bottom-front of the motor which is also partially hidden by the rock guard underneath the front of the car, so you probably won't be able to see those, but they're probably fine at ~50k miles.
Some side maintenance stuff:
Oil should be replaced every 3k miles.
Though they don't fail as often as the NA's, keep an eye around the seam between the motor block & head for any seepage- this will indicate a failed head gasket & if left unchecked could result in complete engine failure. Keep in mind though- the gasket failure on these is generally caused by usage + negligence (though some oddballs do occur, mostly on NAs... basically don't worry about it until later).
Definitely suggest what Roy posted, also I'd check if the fluids are filled to the appropriate levels, especially the oil & coolant reservoir.
Good to know brotha, I'm excited. I've always been a subaru fan, I've always been a wanted an sti wrx, but the baja has been a very close 2nd favorite. Glad I finally got one.Guacamole wrote:Most of the stuff you'll have to worry about is after 100k miles, but just remember the golden rule: Love your Subie & it'll love you back.
Best of luck to you!
That's my understanding too. Little filter in there gets clogged and just like you said starves the turbo. People are saying to dig that little filter out, replace the crushwasher and button it back up for an easy fix... might just do that in the parking lot lolroywitty312 wrote:I could be wrong here but I think:
The banjo bolt is a bolt on the lower side of the turbo that sometimes gets clogged or just goes bad and starves the turbo of the necessary amount of oil.
I strongly disagree. Most maintenance periods are miles or years whichever comes first. I've seen more cars (and even have one) ruined by lack of use with low miles than maintained high miles.Guacamole wrote: Wed Jan 24, 2018 9:52 pm Most of the stuff you'll have to worry about is after 100k miles, but just remember the golden rule: Love your Subie & it'll love you back.
