Gas tank not filling properly
So this has happened the last 3 times I've filled up, each at different gas stations. It doesn't matter how I hold the nozzle, how far it is in. But I can only fill up for maybe .3 gal and the pump stops, I can hear the gas fill up the neck. Like there is something clogging the filler neck because once the pump clicks off if I pull the lever again it will shoot gas back out at me. And ideas or helpful tips?
- TastyHuman
Re: Gas tank not filling properly
I don't mean to be insulting here but are you sure the tank is empty?
Could it be that your fuel gauge is broken and you don't actually need any more?
- TastyHuman
Or maybe some kid stuffed his action figure down the pipe...
That was actually my first thought. Maybe I pissed someone off and they stuck something down there, but I don't know. And yes I'm sure it was empty. That's why it took me 30min to put in 7gallons...TastyHuman wrote:Or maybe some kid stuffed his action figure down the pipe...
Could get one of these and take a look, should be safe as I don't think they generate any heat:
https://www.amazon.com/Fantronics-Endos ... =borescope
But don't sue me if you explode yourself
