Lift kit template needed.
millarg
Post by millarg »
Afternoon All,
Gotta do some suspension works (tie rods, control arm bushings and ball joints) thought I might as well lift her at the same time.
I'll be using 2x 3/4 pieces of high density plastic (all I can source locally) for a total of 1.5 inch rise.
From what I've read, current suspension/drive shafts can handle a 2" lift with causing problems - is this correct?
Would greatly appreciate any advice and the templates necessary to cut the plastic.
After the lift, I'll have her aligned and get some new tires (what is the largest she can carry with out rubbing - I'm using original rims).
On a separate note, was checking under the rear, planning on changing the diff oil this weekend - man the rear differential is "dainty" :D
Thanks in advance,
Glen
2003 Silver Baja Sport AT
1978 Porsche 911 SC
2000 Nissan Frontier Crew Cab V6 manual
1999 Kawasaki KLR 650
sfeather11
Re: Lift kit template needed.
Post by sfeather11 »
PM sent
Conquest-King
Post by Conquest-King »
2003 Subaru Baja with a Snuglid and a 2" lift
