Steering pump noise - fixed
millarg
Post by millarg »
Bought my 03 sport with a whiny steering pump, fluid level was OK, so assumed I'd have to replace it.
You-tube to the rescue, searched noisy steering pump and got several returns.
Short version is - screen in pump reservoir becomes blocked causing fluid starvation to pump and whining
Solution, remove reservoir and clean (carb cleaner), replace, refill and....... Result :o) all good now.
Managed to spray a little ATF around in the process, but otherwise quick and successful repair.
I have a little noise at full lock on both sides, not sure if this is normal or damage from use prior to repair, but it is very slight.
2003 Silver Baja Sport AT
1978 Porsche 911 SC
2000 Nissan Frontier Crew Cab V6 manual
1999 Kawasaki KLR 650
Re: Steering pump noise - fixed
I replaced my power steering belt to fix the problem...I wonder if the problem is a combination of the two. I realized that to tighten it any more resulted in the tensioner bolt actually rubbing on the belt. I opted for the next belt smaller and it has worked perfectly! cold starts all the way left and right...no squeal. This has been a common problem for me; second time in two years. I will definitely be looking into what you did. So basically, just take out the reservoir, clean filter, and replace?
millarg
Post by millarg »
bajaguy wrote:I replaced my power steering belt to fix the problem...I wonder if the problem is a combination of the two. I realized that to tighten it any more resulted in the tensioner bolt actually rubbing on the belt. I opted for the next belt smaller and it has worked perfectly! cold starts all the way left and right...no squeal. This has been a common problem for me; second time in two years. I will definitely be looking into what you did. So basically, just take out the reservoir, clean filter, and replace?
I had a belt "squeal" which tightening the belt cured, the noise I refer to was a groan/whine which happened while turning the wheel (either direction).
As you mention, real simple, just removed reservoir (check you-tube) and sprayed carb cleaner into all three openings (cap, fluid return and draw) until it runs clear (and then some), the "filter (presume it's simply a screen) cannot be seen or removed. Apparently dealers simply replace reservoir to cure issue - cheaper this way.
I also tried to drain system of all old fluid - put and hose on fluid return line and into old oil container, turned on engine and went lock to lock and wheels a few times (I had her up on jacks) - this forced any old fluid out - unfortunately I didn't secure hose to collection drum properly and sprayed old fluid everywhere (I had told the dogs to move, but the didn't listen!). Now I am sure this technique for removing old oil would be frowned upon as it runs the pump dry and could potentially cause damage, but I was quick :D
1978 Porsche 911 SC
