H6 EZ30D 5 SPEED Baja !!
- mikenmel08
Re: Hello All, Newbie inside, but EZ30D Baja !!
What kind of coil overs are you using? Also what adjustable camber kit?
Thanks
Thanks
megan racing coilover with adjustable front top plates...
also I have the stock camber bolt on all 4 corners...
don't need nothing more
I also got some konig crosshair 19 x 8 with 245/35zr19 rubber on them yesterday
The 1st BAJA with EZ30d swap and LGT05 Tranny !!!!!! I love torque !!!!
new pics on the first page... I think I'll remove the roof rack and I'll plastidip in gloss black all the silver molding...
- mikenmel08
Those wheels look good on it....Any clearance issues?
lol... in fact I just put them on.. the car still have no cooling fans, son I can't roll with it a lot...mikenmel08 wrote:Those wheels look good on it....Any clearance issues?
but no clearance issue at all... remember that I'm also on coilover....
well damn, I still haven't changed the head gaskets, but I FINALLY RECIEVED MY 2 FANS and rolled a little with it... I can say that I have no clearance issues with the wheels in fact I think I'll lower it more and put 1in spacers for next summer, I still have one bug with the vss pro ( not working under 30km/hr) pretty sure it's a bad ground...
and also still need to get a proper exhaust setup...
To run the car without check engine light I need to keep the TCU.. but I have to cheat all the sensors and solenoids... here's what I did for now...
One box goes inside the car (the one with the transistor) to properly get the ecu and tcu pin grounded with a 5 speed car
The other goes outside (the 8 big resistor)to mimic all the solenoids in the transmission
IF EVERYTHING WORKS PERFECT AND IF YOU GUYS NEED IT, I COULD MAKE THEM AND SELL THEM !!
Still not installed in the car, but it should be all wired in the couple next weeks, I want to have it running for this winter
Re: H6 EZ30D 5 SPEED Baja !!
I added the McIntosh system to my 03.... I love it. Mine has the minidisc player too... B-)
you added all the wiring with the radio, the underseat speaker amp, the better speakers and the sub ?????tomato_88 wrote:I added the McIntosh system to my 03.... I love it. Mine has the minidisc player too... B-)
or just the radio...
The whole thing.
I had to custom make a sub box to fit under the seat.
That's nice which sub did you used?tomato_88 wrote:I had to custom make a sub box to fit under the seat.
Could someone pm me whom has done this swap or a similar swap I have some questions I’m unsure of I’m going 03 outback wagon h6 to a 03 legacy wagon 5-speed. Much appreciated thanks. What parts from the 04 can I use PS pump, AC compressor, throttle cables?
How easy was it to connect the automatic climate control system? Was it a simple plug and play or did you have to mess with the wiring? I'm considering swapping on into my 2006 Turbo MT...
