Will these lights work?
subufin
Post by subufin »
will these headlights work in my 06 baja, or do i need to modify to use these kind of bulbs because as far as i know the ones i have in there now are just stock.
http://www.amazon.com/Hipro-Power-2005- ... B003LNCRPE
Thanks im not too good with this stuff.
mladen99
Re: Will these lights work?
Post by mladen99 »
will work, but I do not know what quality is. I enjoyed piaa that one of one of the best. But if you want a real light to get real HID kit
From Bulgaria / Europe
WillGT
Post by WillGT »
will work, but highly recommend not buying these. blue coated lights do give the appearance of whiter lighter at a major sacrifice in either 2 forms. 1 these could be normal wattage in which case the blue coating will reduce the amount of visible light or they could be higher wattage to compensate for the reduced light in which case you will need a new wiring harness. Trust me, don't buy these I went down this path a few years ago and wasted lot of money because they burn out so quick as well. If you want good light from halogens buy yourself a set of Philips, Osram or PIAA otherwise go for the true HID retrofit upgrade.
edit: if you look at the page the wattage says 100/80 watts. Normal wattage is 60/50 I believe. So yeah your running higher wattage to compensate for the blue tint which can damage the wiring harness in the long run.
subufin
Post by subufin »
thanks guys for steering me clear.
