Baja Tail Lights
5speed_or_die
Baja Tail Lights
Post by 5speed_or_die »
Hey guys,
Trying to locate a set of tail light lens'. The lens' are cracked on mine, sadly bought them that way.
Been a true nightmare. if anyone even has any ideas how to fix the plastics so the water stops pooling, ill take what i can get.
greymud
Re: Baja Tail Lights
Post by greymud »
If you do a restoration on them, the last step is UV clearcoat. Maybe multiple coats would seal the water out.
05 NA 5MT
FlyByNite
Post by FlyByNite »
A little carefully applied acetone would weld the plastic together.
Yep, got a matching ARE cap.
2003 226,802 miles so far.
Enjoy
FBN
