Smells like burnt oil
Oil smell
Re: Oil smell
I have a 2005 Baja when I turn off engine it smells like oil on exhaust manifold but it don’t use oil oil no oil on garage floor any advice
Re: Oil smell
The lower engine cover will keep small leaks from making it to the floor.
Could be the early indication of a leak or just spilled oil from the last oil change.
Sent from my SM-G950U using Tapatalk
Re: Oil smell
Thanks
Re: Oil smell
It could be a blown innner CV boot. They have a tendency to spray grease on exhaust components... easy to check.
Hope this helps...
Hope this helps...
Re: Oil smell
Plus one on checking the CV Boot. Also, if you catch a split boot early enough you can just add grease and a new boot.
The OEM CV's are high quality. I have replaced a few CV's on Subarus where the rebuilt units were from the git go.
Re: Oil smell
How hard are they to replace? Can you buy replacements from Subaru? Thanks Ronnietomato_88 wrote:Plus one on checking the CV Boot. Also, if you catch a split boot early enough you can just add grease and a new boot.
Re: Oil smell
They are fairly easy to replace. Depending on transmission and year they differ slightly. I saw a good how to thread a while back. I will try to find it and post a link.
In short, can be done in an afternoon.
