I have the 03 Baja Sport, which only has one 12V lighter outlet (unlike later models that have an outlet in the arm console). Right now, I have a 6 outlet strip plugged into the lighter socket (for CB Radio, Sirius Radio, Cellphone Charger, GPS unit, ipod, etc).
I want to hardwire that strip into the Electrical system. Can the sockets be hardwired to stay hot when the key is out? Is this move ill-advised--could it drain the battery?
I am wondering, maybe I should just splice it into the exiting lighter wiring.
Will I have to run new wiring from the battery? Can I tie to some other
"always hot" electrical source (map lights)?
Can I tie to a blank spot on the fuse panel or should I put an inline fuse?
Does the fuse panel have slots that are always hot? Does it have slots that are controlled by the ignition/acc?
wiring 12v an auxillary outlet to stay hot always?
- davecoon13
watch out for the switched ground issue...
Just beware of the whole switched ground issue...not like a normal ol' US neg ground system. I wouldn't worry about draining the battery unless you are abusing the outlet with something like a DC converter or the like. If you are into that then you ought to be thinking heavy gauge wire and separate fuses, etc......
Hi Dave,
I made my 03 lighter socket hot all the time. I just ran a wire from the load side of the door lock fuse (I think thats what it was), and cut off the power wire on the back of the factory lighter wiring. Used some shrink tube on that connection to keep it from shorting out. I have a 3 outlet strip hooked up to it, so I can charge my phone if the ignition is off, or my nephew can play games with the key off. Also works nice to keep the travel refrigerator running when the ignition is off.
Mike
Mike
