Front Window Seal causing loud buzzing noise
Alpha Wolf
Post by Alpha Wolf »
:cry:
I have a loud buzzing noise that comes on at highway speed with a cross wind.
I used painters tape to find it goes away if I tape up the inner edge of the dirvers sided of the windshields vertical seal.
Anyone else experience this?
Do I need to have the windshield reinstalled?
solutions and suggestions wanted...
Thanks
2005
Turbo
BAJAhumbug
Re: Front Window Seal causing loud buzzing noise
Post by BAJAhumbug »
Alpha Wolf wrote::cry:
Thanks
edit: re-read and I have no suggestions.
mbaksic
Post by mbaksic »
Sounds like the moulding is fluttering in the wind. Might be able to put some black RTV under it to see if it goes away. The prob with using silicone is that the moulding won't be able to be used again if you need to have the windshield pulled out. I have some amount of noise with higher winds and stuff, just ignore it. I fixed so many problems like this years ago at the stealership where I work, I refuse to fix mine unless it gets REALLY bad.
Mike
bajasine
Post by bajasine »
Mine does that too. I've learned to ignore it.
2003 Sport
DVD/Nav/iPod/Bluetooth headunit
HID headlights
vabaja
Post by vabaja »
Hi Everyone,
My first post! There is an inherent problem with wind noise on the Baja's front windows--both driver's and passenger side. The dealership knows all about it--if your Baja is still under warranty, they'll fix it by replacing the triangular black rubber gasket on the lower front area. Had a friend who had the same problem--was out of warranty--and told me that if you squeezed this guiding gasket together (window down) it will help.
Vabaja
All who wander are not lost
Alpha Wolf
I used painters tape to track down where the buzz was coming from.
It was the drivers side vertical post / windshield seal. The outside is just barely touching the post. At speed with the wind crossing it is getting sucked up and released.
I used some clear silicone to fill the void between he inside of that part of the seal and the post behind the rubber.
Buzz gone.
Yes, it was out of warranty
2005
Turbo
