Were is Temperature Probe for Dash Thermometer?
- davecoon13
Where is the sensor for the dashboard thermometer (for outside temp) located? It seems like it is sometimes affected by the engine heat. The outside temp displayed on my dash though is usually within a degree or 2 of the radio weathercast, except when I first start the car after it has been sitting a while.
I have not looked for mine, but it has to be in front of the radiator, so it will soak up some heat when standing still. Once you start moving though, it should be pretty much on the money. It takes mine about 3 miles of driving to get it to read accurate, especially when it is warmer outside. Mike
I had installed a directional/temp display/auto-dimming mirror in my mom's Toyota Highlander and had to mount a probe for the temp gauge. The probe was probably about the size of a Sharpie marker cap and the instructions said to try and mount it near the front bumper ahead of or below the radiator. The Baja's probe is probably similar in size and location, but being a factory installed item it may be more concealed.
-Pow
-Pow
- davecoon13
