What ODB2 Protocol is supported? ISO9141, ISO14230, KWP2000
davecoon13
Post by davecoon13 »
I sawthis auction on Ebay for a USB Powered ODBii Code reader. It shows Subaru, will it work with a 2003 Baja?
It supports ISO9141, ISO14230, (KWP 2000). It says the car must have Pin7. Does the 03 Baja have Pin7? And I cannot seem to find where the ODBii Connector is. I didn't see it under the dash or hood, any ideas?
cliffhanger
Post by cliffhanger »
most of the OBDII that i have seen have been under the steering column on the left side.. not sure if ours is, i havent looked for it yet. It could be tucked up in there.
'05 Baja-T M/T white/silver
370 awhp
Hawk296
Post by Hawk296 »
OBDII port is on the drivers side at the bottom of the plastic kick panel on the far left side. if you see the hood release lever you are in the right area.
davecoon13
Elm 327 Protocol for On Board Diagnostics 2
After reading on the Internet (not always the most accurate source of information) that Elm 327 protocol for On Board Diagnostics 2 (ODB II) is supported by virually all cars now a days, I went to the Auctionstealer.com to snipe an ebay auction for a USB ODB2 Code Reader that is Elm 327 complaint.
Does anyone know for certain if this is compatible with a 2003 Baja Sport?
I will tell you in 2 weeks if it ever gets here from Mainland Communist China.
Dave Coon
www.nflcrimes.com
SilverStone Metallic
2003 Baja Sport 4EAT
"Capped" with A.R.E. Topper
davecoon13
Need Freeware for USB ODBII Code Readers
So I bought the ELM327 CANBUS USB ODBII Code Reader, but I haven't hooked it up yet. It did not come with any software. Are there suggestions for freeware that is for code readers?
Dave Coon
www.nflcrimes.com
bajabob
Post by bajabob »
Well dave depending on the reader you might not need any software, just a list of trouble code numbers and what they mean. The reader I have used on the vans at work just pluged in under the dash and turned on, then you would turn the van ignition to the on position and wait a few seconds for any codes to be read and displayed. you would then look these up.
What does your reader look like?
Bob
davecoon13
bajabob wrote:What does your reader look like?
Bob
It is this USB Reader from EBay. It is not a standalone reader that displays codes, it must be hooked up to the USB port of the laptop. I haven't downloaded the reccomended software yet. It doesn't display codes like a standalone reader, it relies on the Laptop for the interface.
Dave Coon
www.nflcrimes.com
bajabob
Post by bajabob »
Hey dave just found a link for this - might be what your looking for -
http://www.openecu.org/index.php?title=Main_Page
Bob
BajaGermany
Post by BajaGermany »
The OBD II-Protokol for the Baja is:
ISO 9141-2, KB 0808
Just checked it with my standalone-OBD-scanner...
Baja Sport MT with LPG
davecoon13
Hooked it up, it works great. My only complaint is that the position of the ODBII Socket (under the coin holder, to the left side of the dash) interferes with driving when there is a USB cord tethered to it. the code reader works great.
Dave Coon
www.nflcrimes.com
