Anyway, here are the symptoms, anyone else ever experience this.
When I turn the vent control knob to any position OTHER than the 2 defrosts, I can hear a panel in the dash repeatedly closing, then reopening, closing, opening etc... bump, bump, bump-bump, bump like that.
AND if any vent settings are selected that include the dash vents, air does NOT come out of the dash vents.
Am I correct that this unit works on vacuum? Is it possible there is just a tube or hose that has come off the fitting.
OR, like the instructions for the Sport Activity Light install (which include HU and HVAC removal warn) could I have damaged the HVAC unit when if I failed to disconnect the temperature control clamp from the lever under the dash????
Only thing is it all pretty much worked fine for more than a month after my install. Well, it sorta worked the same as always, which meant there was an intermittent tapping once in a while.
Other question, should I pull it apart and try to fix it myself or do you think I'll be able to talk a dealer into covering it, even though it might have been my fault.
THOUGHTS?
Kev
