dudes i got squeaky windows. Sounds bad but it only happens when there is high humidity or after a day of chemtrails. Is there anything to put on the window for that or is it a dealer issue?
thanks
squeaky ass windows
My drivers window squeals like crazy when it wet/damp out, I have just ignored it. If I didn't work on cars every day as my job, I would prolly not be so dam lazy about gettin it apart to see what I can do. But as long as it goes up and down ok, I won't fiddle with it. I think it is the stabilizer that rubs up against the glass that is makin the noise. Now that I think about it, you can see a slight rub mark on the glass when it is damp. It prolly needs to be moved away from the glass a bit. But that might make the window rattle when it is partially down. If I were you, take it to the dealer and see if they can do anything. They should be able to ajust it a bit. Mike
