Does anyone have the pinout for a 2006 manual transmission turbo Baja? Local dealer can't seem to help me, and I've called others who aren't willing to help,either. Anything you folks have would be appreciated, as I can't find anything for my specific vehicle, and desparately need it to repair some wires.
On another note, what is the easiest/quickest way to check the plugs on this vehicle? I have a decent amount of tools, including swivels, extensions, etc ...
Thanks again.
Need wiring diagram to ECU for 06 MT Baja Turbo
Re: Need wiring diagram to ECU for 06 MT Baja Turbo
From this thread: viewtopic.php?t=2588
And
20Baja06 wrote: Sat Mar 08, 2025 11:12 am Here’s what I have:
2005
https://www.dropbox.com/scl/fi/osa4titc ... x61r5&dl=0
2006
https://www.dropbox.com/scl/fi/qsup64tb ... b65ew&dl=0
Each contains a .zip file for that model year.
And
There’s also https://charm.li/ which should have the information you’re after, albeit a little more difficult to navigate.anarchy1024 wrote: Thu May 22, 2025 10:05 pm You can check out:
https://jdmfsm.info/Auto/Japan/Subaru/B ... a%20only)/
https://sl-i.net/FORUM/showthread.php?1 ... el-USDM-EU
